Skip to topic | Skip to bottom
Home"Wealth without money..."
Main.PonokoUpperCornerAssemblyr1.9 - 02 Jan 2009 - 23:03 - RussNelsontopic end
Start of topic | Skip to actions
Making the Ponoko RepRap Upper Corners
Main Ponoko Page
Prev StepNext Step
BOM for this page
Upper Corner with 608ZZ bearing fitted. These are the top corners of the RepRap and construction is similar to the lower corners. This time though, there are two corners pointing one way, and two otherwise identical mirror images. Either 608 ZZ bearings or the lasercut ball bearing races may be used.
Set of parts for Ponoko Upper Corner Assembly This is very similar to the Lower Corners, which you should have done by now. Start by locating the components for an Upper Corner Assembly:
Assembling first 3 layers of Upper Corner Put the washers on four M3 25mm screws and join the 3mm segment to the two 5mm segments as shown in the photo. Fasten with washers and nuts just enough to not fall off.
Attaching 8mm segment to Upper Corner Attach the lower 8mm segment in a similar way using four M3 25mm screws and associated washers and nuts, and then add the two M8 washers, eight 4.5mm BBs, and bearing race like you did with the Lower Corners. Or, a 608Z skate bearing if that's your choice.
Actually, you don't have to assemble the bearings just yet - particularly if you find loaded bearings tricky things to deal with. You might find it easier to wait until later, when the Z Axis is assembled inside the supporting framework.
Four Upper Corners Make two like that, and two that are a mirror image of it. Use the bolts & washers trick to keep them together while you assemble the other framework bits.
Main Ponoko Page
Prev StepNext Step
-- VikOlliver - 14 Nov 2008
to top
I Attachment sort Action Size Date Who Comment
dsc04433.jpg manage 53.3 K 14 Nov 2008 - 09:35 VikOlliver Set of parts for Ponoko Upper Corner Assembly
dsc04434.jpg manage 72.2 K 14 Nov 2008 - 09:35 VikOlliver Assembling first 3 layers of Upper Corner
dsc04436.jpg manage 68.2 K 14 Nov 2008 - 09:36 VikOlliver Attaching 8mm segment to Upper Corner
dsc04437.jpg manage 70.6 K 14 Nov 2008 - 09:36 VikOlliver Upper Corner with 608ZZ bearing fitted.
dsc04438.jpg manage 72.1 K 14 Nov 2008 - 09:37 VikOlliver Four Upper Corners
You are here: Main > PonokoRepRap > PonokoCornerAssembly > PonokoZMotorAssembly > PonokoUpperCornerAssembly
to top
Copyright © 1999-2009 by the contributing authors. All material on this collaboration platform is the property of the contributing authors.
Ideas, requests, problems regarding RepRap? Send feedback
